vcPointSet
Used for creating and rendering point clouds and/or data points.
Module: vcGeometry
Parent: vcGeometrySet
ColorConfigurationvcPointSetColorConfigurationRWGets or sets the color format for points. By default, the color format is RGBA.
IncrementalBoundUpdateBooleanRWGets or sets if the bounding box should be updated on every added point or not.
PointCountIntegerRGets the number of points in the point set.
PointSizeRealRWGets or sets the size (in pixels) of points in set.
ScaleRealRWGets or sets a factor for scaling the point coordinates. In other words, this scales the volume of the point set.
addPointIntegerReal x,
Real y,
Real z
Adds a point to the set. The point coordinates are in World coordinate system. The point is assigned default color.
x (float): X coordinate of the point.
y (float): Y coordinate of the point.
z (float): Z coordinate of the point.
int: The index of the new point in the set.
addPointIntegervcVector pointAdds a point to the set. The point coordinates are in World coordinate system. The point is assigned default color.
position (vcVector): The coordinates of the point.
Real y,
Real z,
Real r,
Real g,
Real b,
Optional Keyword[a = Real]
Adds a point to the set with the given color. The point coordinates are in World coordinate system.
r (float): Red component of the color.
g (float): Green component of the color.
b (float): Blue component of the color.
a (float): Alpha component of the color.
addPointIntegervcVector point,
vcColor color
color (vcColor): The color.
clearPointsNoneNoneRemoves all points from the point set.
getPointColorvcColorInteger pointIndexGet the color of the point with the given an index.
pointIndex (int): The index of the point.
IndexError: When the index is out of range.
vcColor: The point color.
getPointPositionvcVectorInteger pointIndexGet the position of the point with the given an index.
vcVector: The position of the point.
setPointColorNoneInteger pointIndex,
Real r,
Real g,
Real b,
Sets the RGB components of the color of the point at the given index.
Leaves the A (alpha) component unchanged.
vcColor color
Set the RGBA components of the color of the point at the given index.
setPointPositionNoneInteger pointIndex,
Real x,
Real y,
Real z
Set the point position at the given index.
vcVector position
updateNoneNoneUpdates the bounding box of the point set.
Example: Render Point Cloud
"""Create point cloud with random data"""
import vcCore as vc
import vcFeatures as vc_fea
import vcGeometry as vc_geo
import random
app = vc.getApplication()
comp = vc.getComponent()
cloud_size = 1000.0
point_count = 100000
cloud_feat = comp.findFeature('PointCloud')
if not cloud_feat:
  cloud_feat = comp.RootFeature.create(vc_fea.vcFeatureType.GEOMETRY, 'PointCloud')
if cloud_feat.Geometry.GeometrySetCount == 0:
  cloud_set = cloud_feat.Geometry.createGeometrySet(vc_geo.vcGeometrySetType.POINT_SET)
else:
  cloud_set = cloud_feat.Geometry.getGeometrySet(0)
  cloud_set.clearPoints()
for i in range(point_count):
  x = cloud_size * random.random()
  y = cloud_size * random.random()
  z = cloud_size * random.random()
  r = random.random()
  g = random.random()
  b = random.random()
  cloud_set.addPoint(x, y, z, r, g, b)
cloud_set.update()
comp.rebuild()
app.render()
